wow that looks a little more difficult to make than i imagined. can i ask how much you spent on the needle light kit? and also where did you wire them into? did they come plug and play? or did you have to solder them in? thanks
after looking at the website it seems they don't carry violet ones, but based how these are made I bet it wouldn't be a big deal if you asked them. they weren't hard to wire up, it's basically 1 or 3 LEDs in series on a wire, and the for wires(1 per gauge) get spliced into 1 wire with some resistors(for the 1 LED series) so when you hook it up, all you have to do is hookup the power wire to a 12v source thats one when you cluster lights are(I used a wire on the dimmer switch) and then a ground wire. (and no I don't believe the dimmer function worked for them).
finding a good way to hide those little wires can be tricky, since I used the whiteface overlays it wasn't for me though.
http://www.importintelligence.com/2laand2smnek.html
3 of these 5 led bulb sets in the cluster? Or 4?
the cluster actually takes 5 bulbs. there's the three for the gauges, then 2 others on the sides that use 194 style bulbs. some people have problems getting the two on the very ends to light up, I noticed that I had to jiggle the hell out of the bulbs and then they lit.
And any idea what i would use to change those service lights over to leds? And the turn signal arrows int he dash.
first of all, the 2 bulbs on the very end are part of what you're talking about here. the little gas can symbol for instance won't light up very well without the 194 bulb in the extreme edge of the cluster. every other (service/smaller) bulb in there use #74 bulbs, they're on the same page of the superleds website that the 194 bulbs are on.
wow..... please post finished product!
I'm afraid thats the best I can do. I actually had this installed and working, but didn't like it, and didn't take a pic with it lit up. decided to get stock black gauges, white LED backlight, and red needles. if you look at the II website, then look up the white faces(andys autosport) I think you can pretty much get a feel for what they look like lit up though.
it looked really cool, but when trying to use it I noticed that at night it was really really bright and I found it to be problematic. I'm starting to think this is just inherently a problem with white face gauges. white face is white with black or at least dark colored numbers, and at night they have to switch roles. this means that the dark numbers have to be really bright to stand out against the white face, and the gauges becomes hard to read(especially at twilight) with everything blending together. my sense of it is this; in a city with a lot of bright lights all over the place all night(like tokyo) this would work great. however, where I live sometimes your car is the only light spot for miles, and every time you look at the cluster and then back at the road you can't see very well.
