MetallicSlate »
https://forums.nicoclub.com/metallicslate-u175179.html
Tue May 01, 2012 2:35 pm
So I installed interior and exterior LED's today.
Fogs, Park, Turn Signal, Reverse, Front Dome, Rear Dome, Courtesy. Resistors for the turns to stop hyper flashing.
I disconnected the negative on the battery and every once in a while I'd reattach it to make sure the lights I had installed were working. Especially after wiring the resistors.
So now I'm popping an SES light. I'm wondering if anyone else who has done an LED conversion has popped an SES light after disconnecting the negative battery terminal. I disconnected it because I read that you could blow fuses if you didn't.
So I called Nissan and asked. They said the SES light is only triggered by a failure in the emissions system. I feel like after using the search feature on this site, that's not necessarily true. I've got the Injen MR technology SRI and the Greddy Spectrum Elite exhaust. Both of them are on there nice and snug and the MAF is in there properly. It could very well be a poorly timed failure of an O2 sensor, but I'm thinking with being connected and disconnected a couple of times, the electrical system might be slightly upset with me.
Any insight would be greatly appreciated.
