Qxxx4 »
https://forums.nicoclub.com/qxxx4-u85589.html
Mon May 05, 2008 4:45 am
So i got my LED brake lights in, they look great and are bright since they are 19LED's each and my tailight housing is clear and highly reflective. My problem is that they work when the brake is applied, but you know how at night, if brake is not applied brake lights are supposed to be dim? these arent! I heard that if the light is lit up with engine running the lights are supplied with a greater voltage, but I am sure it wont affect the LED as it is a DIODE and there is one breakover voltage to turn it on, there isnt a dim, and an on. I replaced the original filament bulbs in until i figure something out
I am thinking of maybe having a transistor and resistor circuit inside a waterproof casing connected to the circuit...good idea? any substitutes? I want to do the turn signals, I heard a 6 ohm resistance would work so that they "flash" it makes sense, but the brake light seems alot more complicated as we need 2 different light settings. Any help would be appreciated. This should probably be on an electronics forum, but alot of guys on here have some great electronics background! thanks
