WDRacing wrote:My Chevy Express 5.7 is also TBI and I'm going to remote turbo it one of these days. So I have a vested interest in seeing this through Ray. If you have some decent links with actual info link them dudes up. I'm probably going to fabricate a spacer of some sort that will be directly sealed to the the TBI itself. Something permanently mounted to the TBI so it will be sealed.
I'm going to go the route of subinjection myself. Far easier to tune imho.
I understand if you don't think the 305 is worth all the effort though. I'm starting with a much better platform
Heres some more research I've been doing.
This guy built a pretty suitable adapter plate for the TBI that you might be interested in duplicating and adapting to modify to accept bolts to keep the TBI hat on.
http://www.theturboforums.com/threads/3 ... bo-TBI-305
Post 16, last photo link.
I found a place for injectors:
http://www.injectors4u.com/tbi_injectors.htm
Also found a really good article on blow through setups for carbs- with pics! Most applies to a TBI,too.
http://www.hangar18fabrication.com/blowthru.html
http://www.hotrodders.com/forum/blowing ... 79511.html
Loads of good info here, too.
http://www.thirdgen.org/techboard/power ... stuff.html
But you're right, its hard to justify spending money on a tired old, swirl port head, 305 TBI.
Especially when that same cash can be used as a very good start to a good n/a engine.
At its basic cost (and being conservative finding the right parts for the right price, heres a rough idea of our costs (not including necessities like a Wideband because no matter what FI you use, its required and thus a moot point to include.
T3/4Turbo (used) 700
Fittings 50
External wastegate 150
BOV (used) 50
TBI plate 40
SS lines 79.8
Oil pump 150
Piping, couplers 170
Adjustable FPR 180
Injectors 100
Welding materials 170
Total 1899.8
So $1900, not including the little things like misc hardware, bolts, nuts, vacuum lines, etc that are bound to pop up. Next, we run a cost/risk analysis.
You could also do something like this guy:
http://www.tbi-superchargers.com/TBI-Su ... raina.html
For all intensive purposes, he has a supercharged TBI. Also, there are a lot of good links on the page for what parts he's used.
The kit he's rocking is widely reputable, especially in the truck world.
http://www.tbi-superchargers.com/TBI-Su ... 5_TBI.html
It has a somewhat high cost, but everything you'll need is there, aside from an FPR. Even comes with a PROM to install.
$2375 plus an FPR and injectors leaves you around $2500 with a reliable setup and no headaches.
Or, P1SC kits come up from time to time. Granted, they'll take a bit to make work, but are a little less work than a turbo setup.
http://www.ebay.com/itm/SBC-Procharger- ... 9c&vxp=mtr
But, if I'm looking at spending approx. $2,000-$2500, why not buy a new GM crate engine, add an intake and carb to it and have a reliable driver that still moves quick enough to be exciting?
http://www.jegs.com/i/Chevrolet+Perform ... 9/10002/-1
Its a very tempting purchase and almost makes more sense than spending the same kind of money on a tired old 305.
I don't mind spending the money, and I do want to do something with the T/A, but it should make financial sense, too.
