Learned'd 4 - More Sequels than Rocky, y0. NSFW
Razi
Car: Moo
LOL Ant.
Btw, any of you foos know a good spray paint that closely matches the look of plastic ish?
more specifically, I wanna paint my fan shroud.
PEZi
Razi wrote:LOL Ant.
plasti-dip
Dattebayo
I'm interested in knowing what plastic ish means...
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
Razi wrote:Btw, any of you foos know a good spray paint that closely matches the look of plastic ish?
urine
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
urine
doo watt? :confused:
Razi
Car: Moo
Dattebayo wrote:I'm interested in knowing what plastic ish means...
I don't even know.
PEZi
a can of
will give you
numbnuts240
2011 Ford Focus
2010 Mazda 3
sx moneypit wrote:doo watt
is that like a poo colored incandescent bulb?
Dattebayo
I would choose the color dingleberry.
Razi
Car: Moo
PEZi wrote:a can of
will give you
I rike.
Berry much.
Gracias!
Dattebayo
SHOOP
PEZi
Razi wrote: I rike.
Berry much.
Gracias!
ish works like a dream... you can do so much with it too... like make matte black badges for your car without needing to take them off
krimsonviper
2006 Mazda 3i Sport -Totaled
1989 Nissan S13 -Sold
1990 Nissan S13 -Sold
PEZi wrote:
Razi wrote:LOL Ant.
plasti-dip
:yesnod
TITO!
The early models had 2 major problems were the engine dropping from a faulty read engine mount that got recalled by Mazda, but still isn't a long term fix. The other is smoke coming from the exhaust. I can't remember, or I may not have followed the smoke problem, but the engine drop problem is quickly remedied with a new rear motor mount(RMM).
My choice in motor mount is the TRZ dog gone motor mount I have been drooling over for years. There are 3 different version of fixing it. One is the insert from Corksport. I haven't really heard any complaints from its users. It's a cheap fix($35). I would imagine that it's still flimsy and may not be good for the long run. The next route is AWR RMM. Comes in three strengths: 70, 88, 95 durometers. IIRC, the higher the number, the better strength it has on the motor. This is a waste of time, because it fails just like the stock one. Not as quickly, but it doesn't hold up over time. The TRZ, my favorite comes in 2 strengths: Polyurethane(street) and Delrin(race).
What's important to remember when choosing the different strengths is how much cabin vibrations you'll receive. After about 2 weeks, it should settle down because it needs to break in, but it will increase.
As for engine performance, the turbo and fuel is pretty much at it's potential. If you want anything at 300+HP with a reliable motor you'll have to replace it's whole fuel system and turbo. You can increase it's PSI to the MS6 level since they are the same exact engine and set up, but that's it.
Torque steer is something you will have to correct. FWD vehicles suffer from this. Getting the new RMM, and the new motor mounts that have just hit the public from CP-E.com is suppose to help with it significantly, but no real news on whether it's true or not. They're very expensive and it hasn't been around long enough.
What else do you wanna know?
numbnuts240
2011 Ford Focus
2010 Mazda 3
modding it won't be happening since it needs to stay reliable and i'm just looking for an entertaining dd. i'm more interested in problem like you posted and general reliability stuff.
King Ranzo
Car: 15 Ford Focus ST
So I just got back from the meet I went to. Thought it was an all Mopar meet, but it was an all classics meet. Some REALLY sexy cars there. Here are teh pix:
(Seen this guy at Herra Frush and the local car show I go to on Fridays)
(He has lawn chairs for seats and a shifter that almost touches the roof)
krimsonviper
Oh, well in that case, yeah, very reliable. The new RMM and you should be good to go. What year are you looking at?
numbnuts240
2011 Ford Focus
2010 Mazda 3
gorgeous shelby. and i hate roadrunners. power does not negate fugly.
krimsonviper
Forgot to mention that some will argue that if you do the new RMM, that it will most unindoubtidly(sp?) put new stress on the other motor mounts. No actual facts on it. I haven't seen failures yet. Doesn't mean it wont happen.(I don't think it will)
numbnuts240
2011 Ford Focus
2010 Mazda 3
krimsonviper wrote:What year are you looking at?
1st gen (i've only come across 07-08 so far, but i'm not ready to purchase yet, just researching options). there is a gt for sale right now. it's purdy.
krimsonviper
More on that smoking problem.
SMOKE FROM TAIL PIPES AFTER PROLONGED IDLE PERIODS
Applicable Models
Model Starting S/N Ending S/N Model Spec CX7 2007-2008 000001 209008 P/D BEFORE 2/15/2008 MAZDA6 2006-2007 000001 999999 ALL MAZDASPEED6 MAZDA3 2007-2008 000001 880368 P/D BEFORE 2/6/2008 Related Category/Subcategory/Symptoms
ENGINE / MECHANICAL / WHITE SMOKE,BLUE SMOKE
ENGINE / EMISSIONS SYSTEM / EXCESSIVE OIL CONSUMPTION
ENGINE / EMISSIONS SYSTEM / WHITE SMOKE,BLUE SMOKE
ENGINE / EMISSIONS SYSTEM / BLACK SMOKE
ENGINE / MECHANICAL / EXCESSIVE OIL CONSUMPTION
MTOL - 5505 Dealer Repair Information
Symptom and Conditions
Applicable Model(s) VINS
CX-7 JM3ER ****8* 209008 Produced before 2/15/08
MAZDASPEED6 ALL ALL
MAZDASPEED3 JM1BK ****8* 880368 Produced before 2/6/08
Some customers may experience white/blue smoke from their exhaust pipes
after prolonged idle periods and/or while driving in traffic at very
slow speeds.
This condition may be the result of the turbo's oil supply not being
able to adequately drain out of the turbo during long idle periods.
Vehicles having this concern should be diagnosed using the following diagnostics procedure.
Repair Procedure
1. Confirm that the proper maintenance intervals have been performed.
2. With the engine at normal operating temperature, allow it to idle
for an extended idle period.
Caution:
Closely monitor the engine coolant to the assure the engine does not Overheat.
3. If smoke from the exhaust is present after the extended idle period,
take before pictures of the smoke, then change the oil and filter
using 5W/40 (synthetic). After the oil change, in order to burn off
the oil that remains in the exhaust system, perform the following:
start the engine, check for oil leaks, then let it idle for 10
minutes, after the 10 minute idle period, increase the RPMs to 3000
for 1 minute, repeat idle test to confirm that no smoke returns.
A: If the smoke returns, contact the Technical Assistance Hotline
(Select option #2 for Major Assembly Authorization) with the oil
change history information, to attain an authorization for a turbo
replacement.
B: If smoke DOES NOT RETURN after the repeat idle test, NO other repairs
are to be performed at this time. Explain to the customer that MAZDA
is currently working on an improved positive crankcase valve (PCV)
system to reduce the engine crankcase pressures to allow the turbo's
oil supply to drain from the turbocharger more efficiently This fix
will be available approximately within 90 days and at that time the
oil will be changed back to 5W-30 and the improved PCV system will be
installed
They will prob be sticklers asking for receipts of oil changes, but otherwise this confirms 3 good things.
1. Mazda probably redesigned the turbo around 2/08 and modified the oil lines.
2. New PCV system being designed to help.
3. The smoke should be mostly harmless.
http://www.mazda3forums.com/index.php?topic=149939.0
Razi
Car: Moo
I dun care about your crazy Mazdas. >:D
krimsonviper
dooo eeeet.....
numbnuts240
2011 Ford Focus
2010 Mazda 3
hanging onto a few receipts for a little while is not a deterrent for me. sounds like a non major issue to me that can be dealt with fairly easily, if at all.
numbnuts240
2011 Ford Focus
2010 Mazda 3
krimsonviper wrote:dooo eeeet.....
as much as i want to, i can't right this moment. need to wait a little.
King Ranzo
I'm getting a Contour.
*shrugs*
krimsonviper
Razi wrote:I dun care about your crazy Mazdas. >:D
It's alright! I dun care about your crazy good looking Korean wominz. >: I
Dattebayo
Contour? lol...
I know that some of those shared the same engine as one of the modern Jags.
Razi
Car: Moo
Welp, I painted my zinc coated washers black in hopes that it would stick. It came off the moment I tightened the nut down. :(
King Ranzo
Yeah. It's not a bad little car. 2.5L V6. It'll be a good car for us to share until I get another S13.
krimsonviper
King Ranzo wrote:I'm getting a Contour.
*shrugs*
You poor bastid! :frown:
