jasonsan »
https://forums.nicoclub.com/jasonsan-u96622.html
Sat May 31, 2008 8:23 am
pinch off return line - just gives max fuel psi - no significant change - - cleaned all engine bay ground connections = slight change - - engine performance better, not so much of a stumble now, a/f ratio gauge shifted slightly richer and acceleration improved - not able to monitor my a/f alpha (consult @ work) - checked MAF ground = good, no voltage drop MAF signal wire = 0.2v KOEO 1.2v KOER
@ this point i think ill put my chips on MAF has taken a "lean" shift
i put this engine together w/used parts and has approx 160K on it, engine sounds good, runs good (should be better), and still fun as hell to drive ((been sitting in my garage for 2.5 yrs)
think ill save up for MAF and ejoy my ride till then.
Any insight would be welcomed.
