s13240sx10psi »
https://forums.nicoclub.com/s13240sx10psi-u196736.html
Thu Jan 12, 2012 2:47 pm
hi im new to the fourm but have been searching and reading for a few years. Here is my problem as soon as i shift i push the gas pedal back in a/f ratio will go to 13.-14.7 then way to 17.8 then back to 14.5 and then its fine untill i shift again. When im crusing the a/f ratio somtime will go from 13.8-15.5 back and forth this happens while doing 75 down the interstate. I have seen 30 diffrent kinds of cars and truck on diffrent fourms have the same problem but they never seem to fix the problem. if anyone can help me that would b kick a** below is a list of my etup and what ive done
s13 240sx with ka24det
redtop t25
370cc injectors
n62 blow thru maf
fmic
knock off hks bov
competition clutch six puck clutch
z32 fuel filter new
255 fuel pump new
new manual tps (auto ecu) problem?
new brk7s gaped .28 wires button cap
emance tuned ecu for 10psi
safc 2 (monitoring sensors)
im going to check fuel pressure this weekend and no vacume leaks, vacume read -24 at 850rpm please help!!!!!!!!
