eazye2000 wrote:Yeah, add fuel to the lower section where 'load' isn't that much, and throttle position isn't that much either.
I don't know Nistune that well, but if you don't know how to tune it either, just find someone locally and explain to them what it's doing. They should just be able to adjust it somewhat for you. Preferably on a dyno.
How is the Nistune? I've been debating it for sometime.
The main fuel map is not the problem, there is plenty of fuel being added. The other map that is causing the problems seems to limit injector pulse until a certain rpm/throttle position has been reached. I'm getting a tune this saturday, I just want to make sure the engine is running right so I don't waste my money.
Nistune is pretty good. I don't have any complaints, really. It's nice to be able to see everything that is going on with the engine and how changing certain parameters affect behavior in real time. I'd definitely recommend it.
