SSonic92 »
https://forums.nicoclub.com/ssonic92-u165351.html
Tue Jun 05, 2012 7:27 pm
Well i just finished putting my new turbo on, got that all done and drove it that night, everything was fine. Well the next day i get into it and when i come up to the light all of a sudden it idles down and i see my aem wb start heading full lean. I spray carb cleaner all around trying to find leaks, i dont find any. I go through and check all my clamps and make sure they are all good, dont see anything wrong with them. Look all over my intake for anything off and i still cant find anything. I dont know if they has anything to do with it, i can take my hose off the pcv valve and cap the intake line that runs to it and i idle rich around 11 to 12. while cruising the most ill see is around 13.5 that way though, never hits 14 or higher which is what you want for good gas mileage right? i wanna know why it will run like that with the hose off but with it on it runs like s***, I mean it idles where it needs to around 750 to 850 but its all the way lean, and like i said it just happened all of a sudden. I also noticed my vac on my gauge is slightly lower then usual but cant find a leak anywhere, the only time i see it go up to higher then normal is when i cap the line that runs to the pcv valve. Any help with this would be very much appreciated. And yes i have searched through the 250 or so post on here that pertain to lean idle and other websites, still cant find a similar scenario to my situation.
