I have a 95 240 with a pretty much stock ka24de with 190000 miles that i just got from a friend. this makes it much harder to diag. the prob. because i do not know how it should run. Anyhow it has been pinging when the throttle was bliped quickly and the plug were white. I meen white, lean white. This morning on the way to school it started pinging alot and then the mil came on. front o2 sensor. it was no more than 4 months old. I put a new one on it and it is still pinging.Had to retard timing all the way to get home, scared it was going to die.it is very weird. Fuel pressure is 36- 39 psi. new fuel filter. It has been showing a knock sensor code for a long time. on a consult the alph was around 100 so now i am thinking mass air flow? or cat? this really is testing me. Please help....
there is a ticking noise around the distr. every time i start the car (like bad coil or exhaust leak).
please help [email protected]
