The fuel pump seems fine, its wired through a relay to the battery. I run a map setup, so vacuum leaks are a highly unlikely culprit. Ive changed the fuel filter. The pump and injectors are less than a year old (not clogged or defective)
Im wondering if this sounds like a fuel pressure regulator issue, as in its not maintaining the pressure needed for sudden TPS fluctuations.
What do you guys think?
