BaliLover wrote:
If the threads are destroyed, you won't be able to use a tap to repair them as there is no material for it to cut new threads into.
I don't understand what you are saying here. when you drill the hole bigger, you shouldn't have any threads at all. I did this when my motor was out of the car so it was a lot easier.
1. drill the hole bigger. the helicoil kit should tell you the proper bit to use.2. tap the hole. be sure not to tap the whole thing at once. start off easy with tapping the beginning thread. when the start off thread is made, continue tapping by making 1/2 - 1 full turn, then back it out. repeat this until it's fully tapped. you want to be sure that the metal shavings do not fall into the block. i placed a cotton ball inside to catch most of it. 3. use the helicoil tool to insert the helicoil.4. there will be a little piece that's on the helicoil that you'll have to snip off. with the motor in the car, i would think it'll be a pain in the as$ but should be do able. your done if you reach step 4. hope this helps out.
hint: when your half way through with tapping the whole thing, back it in and out to make sure it's smooth. the MOST important part is just tapping the beginning thread. DO NOT f*ck this part up or youll be in bigger trouble. just be sure the tap is straight before you start tapping the beginning thread. after the first few threads are done, it should be a piece a cake from there. Good LUCK!
