Manzai »
https://forums.nicoclub.com/manzai-u36510.html
Mon Jan 23, 2006 5:27 pm
All of your posts are good ideas. What DRFT240 needs though is to confirm the location of this leak. You can easily check all of these things by yourself. After having removed all of the trunk trim, open the hatch. Yes! you check for the leak with the hatch open. 1)Park the car on a flat surface. 2)Remove any attachment from your garden hose. Take masking tape and tape the hose to your roof (facing the trunk obviously). Turn on the hose and let the water run down the gutters. Increase pressure until water almost splashes over trunk seal and then back off slightly. Now you can see where it is leaking from without having to be a contortionist and wasting your friends time holding a hose. This obviously does not check the sunroof drains (but you can cram your hose in there too)
