es.biggs wrote:I will try to get that bulletin up tonight man, I'll get them off of Alldata at work and try to post it up
Thanks for the TSB idea, biggs. It made me slap my head, since years ago I looked up and found TSB's for water leaks on my 240 but I forgot to do it for my Z (which I just got last year). Instead I've been searching the Web for a good while until I landed here.
There's no free link to TSB NTB93-156 on the Web, but you can go to your library and get it free, or subscribe to Mitchell's:
https://www.eautorepair.net/Marketing/Default.asp
the link to the TSB is on this page:
https://www.eautorepair.net/app/TSBS_AL ... VID=107867
Here is the beginning of the TSB, which contains detailed instructions and illustrations on how to stop the leaks, mainly with strategically-placed Permatex #82 Black Super Weatherstrip Adhesive (Item No. 81850) or equivalent:
TECHNICAL BULLETIN NTB93-156
October 28, 1993
300ZX (Z32) T-BAR ROOF WATER LEAKAGE
APPLIED MODELS: 1990-93 300ZX (Z32)
SERVICE INFORMATION:
On some of the applied vehicles, water leaks may be identified at the following areas:
I. Water Leakage from Body Side Weatherstrip
II. Water Leakage from Body Side Center Weatherstrip
III. Water Leak from T-Bar Roof Assembly
REPAIR INFORMATION:
1. Removal of Body Side Weatherstrip
a. Remove T-Bar Roof Assembly
b. Remove weatherstrip from the body.
NOTE: The weatherstrip is secured to the body with two (2) screws and three clips. (Figure 1)
