I think the pink shield is part of his scheme to trap cold air. The valve covers look nice, but I'm with Sean in the fact that you should've done something special with the timing covers as well. Still looks tight though.NeedCAforS13 wrote:what's the pink thing?
I think the valve covers look pretty sweet... you should have done the front timing cover while you were at it I think it looks even better with it all the same color!
Sean
Oops.. i just grabbed the biggest screwdriver i had, did them up as tight as i could, and they haven't leaked yet :pbiosehnsucht wrote:actually there are specs, for the valve/cam covers, whatever you want to call them. I don't see any offhand for the coilpack cover / ornament however.
2-4 (0.2-0.4, 1.4-2.9) N-m (kg-m, ft-lb)
page EM-5 in the FSM.
obviously you'd want to convert to in-lb's or something more accurate and use a small accurate torque wrench
