elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Tue Aug 30, 2005 4:20 pm
AS far as Im aware, you can just replace the O rings on the injectors. NIssan is crazy in that they use the same design for about everyhting. So what im doing is assuming the Q45 injectors are of the same design as the 240 ones (which i am pretty sure they are, but the 240 ones are just smaller)
So what im suggesting you do, is pull the injector, get hte new O rings, and then re-install..
Also, to verify, the injector is leaking extra fuel at the tip causing it to run rough and rich, or is it leaking elsewhere???? if its leaking at the top, thats a different story.. There are I think 2 or 3 O-rings.....
