s14_sport »
https://forums.nicoclub.com/s14-sport-u34462.html
Sat Aug 09, 2008 5:30 am
well i cleaned out everything i could get my hands on. i took out the spark plugs and used air to get all the gas out the cylinders. took off all the intercooler piping and intercooler and cleaned all that out....there was nearly a gallon of gas in the pipes and intercooler! i even took a wire snake with some clean rag on the end and snaked it into all the runners in the intake plenum and thru the turbo. changed oil and instead of 5 quarts of oil coming out i got about 7-8 quarts of oil/gas mix. it was crazy. i replaced both o-rings on the injectors and before i installed the plugs i hooked up the fuel pump to direct power and made sure fuel didnt come out where it wasn't supposed to. replaced with fresh oil and dropped alittle oil down into the cylinders. I did a compression check to compare to my compression before and compression did get alittle lower. it dropped like 10-15 psi on cyl 1 and 5 and raised alittle on the others???
anyway, i started the car and after alittle while idle got more steady and smoke blowing out of the exhaust lessened.
I will drive her around for alittle while and then do another oil/filter change. and do another compression check and see what happens.
