JNM240 wrote:One other thing i might do is get some dieletic grease (conductive grease usually used on plug wires) and put a little to each injector connection, just to make sure they dont corrode in the future. As i check each of my sensors with age i do this. Helps maintin longevity.
Good luck!!
OK OK, I finally got the clutch issue fixed, Thanks again for all the help... I started to take off the BPV valve, and the fuel rail to get to the fuel injectors. I had bought a seal kit for like 2$ at the auto parts store for only one injector, I got the new oring and rubber coupler/separater thing on the fuel rail end of the leaky injector, when I noticed that one of my other injector nozzle heads was cracked. So i removed that injector to see that part of the plastic nozzle tip had broken off and was stuck in the hole that the injector goes into the engine. While trying to carefully get this "small" plastic piece out of the incredibly small hole, it fell into the hole!!!:eek: So what do I do? Will this cause big problems, will it just ride on top of a valve or something or will it cause some detrimental problem with my fuel injection or pistons for that matter!!!
Please help.. I will be shopping around for new injectors now on the internet. I checked out summitracing.com and want to shop around some more first. Let me know your ideas on this matter. Thanks again.
