bmf512 »
https://forums.nicoclub.com/bmf512-u87664.html
Mon Jan 28, 2008 1:17 pm
I just purchased a 1990 240sx with no mods. After draining, flushing and filling the radiator, coolant appears to be dripping from around the oil pan gasket. No white smoke, no water in oil that I can see so I don't think it's a head gasket issue.
I followed the instructions in the owners manual for replacing coolant. This included removing air plug, drain plug and draining via the petcock valve under the radiator. Was a ***** getting the drain plug out but no coolant drained from there. Only out of the petcock valve.
Once drained, flushed until clear and refilled all looked great and no leaks. The day after I noticed coolant dripping but could not see from where. Only sign was it appeared that it was either coming from directly above the oil pan or from the pan gasket.
Any thoughts?
PS: I am not an auto mechanic by any means. Maintenance only.
