leaky cam cover
originalsin
ok so like my cam cover on the exhuast side is leaking from around that square part, it seems like its 2 pieces? the rectangular part that like comes off of the cam cover toward the back. anyone else have this? what can i do?>
boost_boy
originalsin wrote:ok so like my cam cover on the exhuast side is leaking from around that square part, it seems like its 2 pieces? the rectangular part that like comes off of the cam cover toward the back. anyone else have this? what can i do?>
Change the gaskets and don't over tighten bolts that fasten the covers to the head. Also, place a dab of silicone on top of the half moon cam plugs to help with sealing.
Dee
float_6969
No, he's talking about where the connection for the PCV tube it at.
Mine is doing the same thing and I haven't found a solution yet. It doesn't leak very bad, so it hasn't really been a priority yet.
originalsin
yea mine dont leak bad either, just kinda looks sloppy, im thinking maybe a little leatant on the outside? idk once i pull it out i will investigate more and let ya know if i find a solution
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
Give the section a good soaking in hot soapy water, then rinse in metho, and leave out in sun to dry.
Then run some wick-in locktite threadlock into the gaps. That'll solve the problem.
float_6969
You OZ guys are bunch of genious's, you know that?
