p00t »
https://forums.nicoclub.com/p00t-u5026.html
Mon Oct 18, 2004 11:13 am
its not hard to replace the seals, you need the actual brake seal rebuilt kit, which includes the seals, and may or maynot come with grease, i know the nissan kit comes with the grease.
You'll also need emery cloth to polish the cylinder walls to clean them up and give the new seals a fresh start.
Its not that hard and should take a patient person a whole evening to complete. FSM is recommended so you know where everything goes. Rebuilding the rears are a bit harder and i might recommend rebuilt ones instead, but fronts are easy.
