leaking water??
knowleqe
im stumped, my car is leaking water but im not sure from where actually. it is from this hose that goes into the transmission from the chassis?? im really not sure what the hose is called. it is towards the front of the tranmission on the right side if you are looking through the windshield of the car.
-Nick
quiksilvia
Car: 95 s14 se
try again nick. no sense made.
NISTECH
that would most likely be your a/c evap drain if I understand what your saying. does it seem to only leak after you have run the defroster or a/c. if so this is normal condensation from the a/c evap collecting moisture from the air during operation. kinda like when you pull a soda out of the freezer and set it on the counter it builds up moisture on the surface of the can. your a/c evap does this at a much higher rate. therefore you need that moister to drain off somewhere. this is the location of the drain on most cars.
quiksilvia
Car: 95 s14 se
that hose comes out of the firewall, is about 4 inches longs and points down, and its in that area that u were describing nick
MojoMan
Car: working on cars and women
Ya that is the area. He's right, its for your a/c.
NISTECH
brandon ,
was that bla bla bla enough???
lol :D
quiksilvia
Car: 95 s14 se
huh? from the other post
themadscientist
Does he have a water-cooled transmission or does he mean the heater hose?:)
knowleqe
quiksilvia wrote:that hose comes out of the firewall, is about 4 inches longs and points down, and its in that area that u were describing nick
im not sure if its from the firewall. it seems it is more like from under the passenger seat. and the ribbed hose is about 4-6 inches long if you straighten it out. but what else could it be? :confused: let me try this ascii stuff:
DRIVER'S SIDE- - - - - - - - - - - - - - - - -TRANSMISSION [FRONT]- - - - - - - - - - - - - - - - - ................... ^.................... \---HOSE
sorry if my post(s) are confusing but they are done mostly at night. thanx for answering my questions everyone
-NIck
quiksilvia
Car: 95 s14 se
Under the pass seat is where your brake and fuel lines run. are u sure its water? can u take a picture ? ribbed hose....sure its not a used condom? :)
NISTECH
:withstup
knowleqe
quiksilvia wrote:Under the pass seat is where your brake and fuel lines run. are u sure its water? can u take a picture ? ribbed hose....sure its not a used condom? :)
LOL. why would brake and fuel lines go into the transmission?? haha. but i think it is the A/C moisture. by ribbed i mean like lines running up and down, not side to side. :D
-Nick
