leaking tire??
nismobenzo
Car: 240sx
nothing crazy but i have a 225/45 on my 17x9
they all seem fine but one-which is slowly leaking
it wasnt doing this at first but i just noticed it a few weeks after i get the tires mounted
-do you think it could be fixed by remounting? i dont want to waste money on fat fixing goo for long term reasons
im new to this whole stretch tire thing haha thanks :scratch:
bersh240
put it in your bathtub.
badbob2121
Car: '92 Nissan 240SXS13 Hatch ELLIS JUAN
'12 Ford Mustang GT RTR
could be a bad valve stem....
polk240sx
Car: 1997 240sx kouki
1992 240sx HB project
cover the tire in soapy water to see where the leak is.
nismobenzo
Car: 240sx
seems to be leaking out the sidewall between the rubber and my rims lip
i just cant understand WHY! lol
EnjoiNismo
Car: 93 240sx
polk240sx wrote:cover the tire in soapy water to see where the leak is.
Weeerd.
My friends was just having the same problem.
We just burned them off, and got new ones.
nismobenzo
Car: 240sx
sounds like a good idea! haha i can get em for 25 a tire so thats doable
-just sucks the place i go uses fully metal machines..meaning..
if i dont wana scratch my chrome, i tape up everything i dont want rubbed by metal
GTR24
Car: 1995 240sx
2015 370z
Its leaking around the bead. The tire needs to be remounted with tire-lube, it helps seal the bead. Cleans off any dust particles in the way.
DanThaMan
Car: 1993 240sx
It could also be corrosion between the wheel and the tire bead... if seen that a lot on aluminum wheels. If that's the case your gonna have to do some wire wheeling, some sanding and probably get a new tire. When remounting the tire, make sure they use the wax based tire lube, as it prevents further corrosion.
polk240sx
Weeerd.
lol
nismobenzo
Car: 240sx
DanThaMan wrote:It could also be corrosion between the wheel and the tire bead... if seen that a lot on aluminum wheels. If that's the case your gonna have to do some wire wheeling, some sanding and probably get a new tire. When remounting the tire, make sure they use the wax based tire lube, as it prevents further corrosion.
my wheel is three weeks old out of the box..so ill just assume the post before yours is the one i should check into..
thanks for the info on the tire lube..i didnt even think leaking out of the bead to be a possiblity until this all happened!
