Post by 0311rifleman » https://forums.nicoclub.com/0311rifleman-u52689.html Sun Dec 24, 2006 4:17 pm
Post by mrbizness1 » https://forums.nicoclub.com/mrbizness1-u24256.html Tue Dec 26, 2006 1:55 pm
Check your coolant lever in the radiator. If it is to low then you will get to much air into the heater core instead of the hot antifreeze needed for heat.You need to find the source of the leak before you damage the engine.0311rifleman wrote:my radiator is leaking somewhere and my heat only coems on when i drive wats wrong with it
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
