Leaking sunroof
bigdenx
Car: 1993 J-30
Hello, Any insight on a fix ? I have heard a drain duct may be plugged and having trouble locating that. Is it a BIG fix to install a new gasket ?THANKS for your help
BIGDEN
yodawill2000
Car: 94 Infiniti J30
The drain holes are on the front left and right corners.You may have to brush away any debris to even see them.I had to.
bigdenx
Car: 1993 J-30
Hey!
THANKS for your assistance...fast as well! Got the problem solved!
Denis
yodawill2000
No problem !!Glad your sorted out.Welcome to NICO !!!
driverdriver
Car: NICO's longtime resident Canuck!!!
We're all here to help.
Yoda, quite often goes above and beyond and its greatly appreciated!!!
yodawill2000
Oh puleeeeze I repeat what this site has taught me.lolI came from Detroit Iron.Hands on since 8. (Brother Raced Super Modified)I just love good engineering.These things are WAY over engineered.Love a good Challenge.Many others here have forgotten more than I know.
joetraynor
Car: 1994 Infinity J30 T
Good Afternoon.So here is my deal. My Sun Roof is not working, I think I need to replace the motor, It also leaks, right now my passenger floor is soaked. (i live in Seattle, so you can imagine.) I need to be able to get to get to the drains, Should I take inside ceiling cover off? What do you suggest?Thanks
yodawill2000
Ive been told if you take the switch panel off up there there's a way to crank the sunroof back manually.Can anybody confirm this ?Ive never had the need to try.
go here and scroll down to Pic 13.
http://www.fuzzycats.com/docs/sunroof_repair.pdf
I'm guessing that's where you would manually operate it.
Skapunk4everr
Car: 95' j30
Before you crank it back, I would check to see if any fuses are shot.
As for the manual open method, I have not tried it yet but i believe there is a lever the locks down as an anti-theft device(In my J i can hear a small click when it finishes closing) but i'm not sure. If you force it open you may damage it.
driverdriver
Yes the sunroof can be manually cranked, with either the tool supplied in the Infiniti toolbox(if you still have the Infiniti toolbox and/or tools) or a household screwdriver.
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
I have used a piece of metric hex stock in a battery drill lube the cables with silicone as you open and close it.
yodawill2000
Someone here posted the best thing to use is "Drip-less" candle wax.Don't remember the chemical name but it supposedly last ALOT longer than silicone or Lithium grease.I apologize for not remembering the member that posted that.
