sublime187 »
https://forums.nicoclub.com/sublime187-u89926.html
Wed Oct 08, 2008 12:56 pm
I had all fluids changed when I bought the car back in February. At the time my mechanic could not find any fluid loss, I actually took the car to him specifically for this issue probably 3 times. He recommended replacing the PS pump, which he did. That did not fix the issue. He repeated to me that he did not see any leaks whatsoever in the system. Within a couple months, however, the leak became apparent. It's leaking right from the rack. I understand the noise comes from the PS pump being starved. It actually leaks so slow, though, that I don't hear any noise for at least 3 to 4 weeks after I top it off. I actually monitor it frequently enough to make sure that my level is never too low. So is this something I can live with for awhile without causing further damage to the steering system or anything else, simply from the fact that there is PS fluid all over the underbody of my car?
