Easy...
1- Tightening everything.
2- "loan a tool" cooling system tester. Test system at 1.5 bar. You want to see the cooling system hold that pressure at 1.5 bar for at-least 30 minutes. If pressure does not hold pump back to 1.5 bar and listen and look for the leak. Fix that leak and move to the next step If your sure there is no external leaks, and your dropping pressure, then you need to check your oil for intermix and check compression.
3- Properly bleed the system. Use a 60/40 mix 60%water, unless you live in the arctic.
How to bleed
Jack front on the car up
Use a coolant bleeder funnel and fill it
Squeeze the hoses and burp the air out
put the heat on hot, fan off
Start car and let it run
As the engine heat up, the air will bubble out of the funnel.
Once the engine is at normal temp the bubble should stop
Then open, the bleeder screw to make sure, once coolant comes out close it. wait about 30 seconds and do it again, Keep doing this until there is no air.
At no time let the funnel go empty
Plug the funnel and put the car on with the engine running.
Take a ride make sure temps are good, run the heat, then turn the heat off and just drive. Repeat if needed.
