Its alot easier than people say it is but i would say the hardest part for me was getting the steering column to bolt back in the perfect spot. but actually getting the rack out is so easy just get a tool to remove the tie rods from the spindle.hbpignosePA wrote:just get a new one
have you pulled a rack before?
its a pita
you definately don't want to chance it with another beat rack.
300 is not that big of a deal if your doing the work yourself
Do NOT use any of these products anywhere in your car. They are horrible horrible horrible for everything.motoman399 wrote:the lucas power steering stop leak is guaranteed to stop any seal leaks or your money back. might want to try it....
lol is that right. they have a pretty good rep for being that bad. can you explain to me how they are so "horrible horrible horrible"?Philipio wrote:Do NOT use any of these products anywhere in your car. They are horrible horrible horrible for everything.motoman399 wrote:the lucas power steering stop leak is guaranteed to stop any seal leaks or your money back. might want to try it....
no, i used o'relly brand whatever in a gallon jug....Taylor008 wrote:Just to throw this out there... You used ATF fluid for the Powersteering fluid, right? Dextron III or higher. PS fluid is too thin of a liquid for our racks.
Or so I have been told.
Chris28 wrote:http://cgi.ebay.com/ebaymotors/NISSAN-S ... 518wt_1165
Might want to install these no matter what route you go with. When I replace my rack I'll be doing a re-manufactured unit but with these boots on it. Stock and stock replacement boots always tear, especially if your car is lowered.
Not a 100% sure if there are any but i do know that the s13 and s14 use a different passenger side bushing for the r&ps13sickboi wrote:i have a chance to trade some parts for a rack from a 96 s14! are there any significant differences in the rack between s13 and s14?
haha yea thats a thought! ive driven it alot without fluid in it (cz it all leaks out) and its not so bad...raven2345 wrote:Convert it to manual steering, the proper way. It feels great, once you're moving anyways.
if you have money go ahead and do it.... if you dont give a f*** like me... then, um..thompsn wrote:I'm asking because my rack is leaking out one of the boots and I'm trying to decide if I should replace the whole thing or not.
I mean if I HAD to have the money I could get it, but if I can get away with just replacing the inner tie rodss13sickboi wrote:if you have money go ahead and do it.... if you dont give a f*** like me... then, um..
