Leaking PS fluid right at the connector... what to do?
adrianfromthecastle
Car: 1992 Nissan 240sx
okay, I'm leaking PS fluid on one of the connectors on the lines (circled in red). Any suggestions on what to do (such as getting some sort of sealant or new O ring or something..)? No power steering sucks, so I'm probably gonna attack this problem tomorrow. According to the FSM, it just said remove and reattach, but I'm just afraid it'll leak again (and leave me without power steering =/), but it didn't say anything about replacing an o ring or add some kind of plumbing sealant or anything.
White Comet
Car: fc, s13 and mazda6, Sierra
permatex has a contact cement that might work as a temp fix. but it either needs tightened or a new washer/o ring
2projects2many
Car: '91 S13 SR20DET
Yeah, I'm pretty sure sealant is not going to hold under that type of pressure. There must be an o-ring or washer in there.
Modified by 2projects2many at 8:54 PM 12/8/2008
Razi
Car: Moo
There should be an o-ring or washer there, and probably due to age it has worn out and started leaking.
S3t0_S13
Car: Of Nothing But FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL
grow some
power steering is for panzys
DJButton
Car: 2010 Nissan 240sx
Get new line from me for cheap. lol That fitting is an inner O-ring style but you might be able to get by with finding the right size 0-ring and replacing it. It's rather small, also the metal washer on the end of the hardline as well, that should get replaced. If that doesn't fix it then hit me up and I'll give you the special mod pricing.
adrianfromthecastle
well, for some reason, it was just loose. As soon as I got home, I tightened it.
Why it was loose to begin with... I have no clue.
Well see if it still leaks tomorrow.
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
S3t0_S13 wrote:grow some
lol. Actually, no PS in an S13 isn't too bad, as long as your only DDing it.
adrians_s13 wrote:well, for some reason, it was just loose. As soon as I got home, I tightened it.
hmm...maybe it just vibrated/worked itself loose after all of these years.
DJButton
Yeah Justin, I ditched PS awhile ago in my daily S13, I actually really like it.
homeslicej2
DJButton wrote:Yeah Justin, I ditched PS awhile ago in my daily S13, I actually really like it.
I liked it too, except in the parking lot lol. The previous owner had the P/S pump go out, so he just removed the belt, but didn't drain the fluid, so the rack had blown it's seals out. When I had the SR swapped in, I had a re-maned rack installed. It made the car feel more "jumpy" I guess, esp at speed, but it rocked at slow speeds. If I had to do it over again (esp since I don't drift), I probably would have saved the money and not had the rack installed (or let that shop touch my car /bitter ).
adrianfromthecastle
ugh... I hate not having PS. I can't imagine how it would be like drifting without PS
brizanden
Car: thrased kouki ftw
those rubber hoses wear out after awhile and they leak around the nipple. haha i said nipple. get a new one from dj like he said. I had a ps leak and jsut had to replace two houses and it fixed it all up.edit: er wait is that even a hard rubber hose there? i cant really tell what part u have circled its like 3 things.
adrianfromthecastle
brizanden wrote:those rubber hoses wear out after awhile and they leak around the nipple. haha i said nipple. get a new one from dj like he said. I had a ps leak and jsut had to replace two houses and it fixed it all up.edit: er wait is that even a hard rubber hose there? i cant really tell what part u have circled its like 3 things.
no. It was a hard line.
brizanden
ohhhh.. yeahhh those are expensive to get new ones lol.
White Comet
adrians_s13 wrote:ugh... I hate not having PS. I can't imagine how it would be like drifting without PS
lack of ps in teh reason i didn't romp on my car at the carlisle nicofest
DJButton
If I did anything but cruise around in the S13 it would have an MR-2 electric pump and PS for sure.
homeslicej2
I'm pretty sure that unless you replace the stock rack with a quick ratio manual one, that drifting is almost impossible since you're fighting the steering wheel and wouldn't be able to turn it from lock to lock quickly.
DJButton wrote:If I did anything but cruise around in the S13 it would have an MR-2 electric pump and PS for sure.
MR-2 electric PS pump?
adrianfromthecastle
Dan, can I replace my hardlines with some SS braided lines? Like, do you sell demz? pics if so?
