Leaking Oil Pan
93240guy
Car: 93 240SX SE
I have a 93 240sx with a ka24e. So I have a leaking oil pan. I placed the oil pan gasket 3 times now, all refering to fsm. FIrst two times i used hondabond, last time i used permatex ultra grey. Best seal i had so far, but still leaking quite a bit. Oil pan appears to be in pretty good condition. It lays flat when placed on counter top. So am I doing something wrong? Why wont it seal??? Do you suggest I need a new pan? I dont see that would help, since mine appears to be flat, n gasket would fill any imperfections. What do you suggest i do? Your help would be appreciated.!!
KoopaTroopa
Car: 1991 black hatch
How quickly did you go from laying on the permatex to tightening the pan? When I did mine I had a friend hold the pan just below where it needed to be while I put the sealant around it. As soon as i finished with the sealant he pushed/held it against the block while I bolted it up. Make sure the surfaces are very clean and work fast. If that doesn't help then maybe track down exactly where the leak / leaks are coming from and check for damage. Good luck!
JKL1031
Are you sure its not coming from above, and just leaking off the oil pan?
use ultra black. put it on both sides of the gasket all around, snug it, let it sit for 45 mins. then final torque it.
93240guy
Car: 93 240SX SE
maybe thats my problem.. I tighted it to quickly. i tightened within 5 mins. normally wait til next day to put oil in. I used brake clean to wipe it down. i'm sure its not coming from above. i just did headgasket n stuff. its oil free. i'll do it again once i get other day off. thanks your help.
