My Oil Pan is currently leaking near the passenger side from where it mates with the Engine block. It is definitely my seal that is leaking and something I'd like to fix on my own.
I began looking at the FSM as to how to fix this and saw that there are actually two oil pans (An Aluminum one nested inside of a steel one). Due to my leak must I replace the seals on both? I have never worked with liquid gasket's before, does anyone have any tips of suggestions? Has anyone done this repair?
The FSM also says to use a specialty tool in order not to damage the aluminum oil pan, is this really necessary?
