centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Tue Jul 26, 2016 1:37 pm
Hi and welcome to the forums. I don't have a Pathy, but I've seen plety of oil there on other cars. It is probably coming from the crank pulley seal and being thrown up there by the belts and pulleys. You might want to replace that seal. Being unfamiliar with the car, other things to check out are the PCV valve and the ventilation tube from the valve cover.
PS - Is that white powder corrosion on your battery positive? Maybe clean up your terminals.
