Leaking oil after shutdown sr20det
schmitty1991
Ok so every time i start my 240 it is great never leaks while driving it but whenever i shut it off it always drips and then stops what can i do to fix this and what is causing it?
DuckyD
Car: 1995 240SX
Where is the oil coming from?I would grab a flashlight and start looking dude. Could be your oil feed line for the turbo. Could be the return line. Could be your lower oil pan. Could be the upper. There is really only one way to find out.
Justin35ll
Car: s13 coupe sr20det
a little more info damn seriously man wtf
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
I fail to understand how oil can leak while the car is off... but not while it's on.. That makes no sense what-so-ever. You sure it's not just a small leak, and maybe it's building up and then spilling all at once? Grab a flashlight and start looking with the motor running... I'll guarantee it's doing it with it running though.
Sil80315
Car: 1991 Nissan 240sx
[QUOTE=PyR0NiAk]I fail to understand how oil can leak while the car is off... but not while it's on.. That makes no sense what-so-ever. You sure it's not just a small leak, and maybe it's building up and then spilling all at once? Grab a flashlight and start looking with the motor running... I'll guarantee it's doing it with it running though.[/QUOTE
Its pretty easy actually. The more hot the oil gets the thinner it is so there for it can leak out from fitting but not after it has cooled down. Never heard of people running thicker weight oil when they are to lazy to repair the leak and just need it to last?
I have the same problem. Im leaking oil out of my drain plug but only after Ive driven the car. after it sits and is cold it no longer leaks.
PyR0NiAk
Sil80315 wrote:
PyR0NiAk wrote:I fail to understand how oil can leak while the car is off... but not while it's on.. That makes no sense what-so-ever. You sure it's not just a small leak, and maybe it's building up and then spilling all at once? Grab a flashlight and start looking with the motor running... I'll guarantee it's doing it with it running though.[/QUOTE
That means it's leaking while running too... He claims hes not having any leak while it's running... My point was, the car isn't going to ONLY leak while the car is off.
fightinchunk
i might be having the same problem too...
Sil80315
If its leaking oil its leaking oil very slow. Same goes back to my drain plug. I can look under my car for an hour and see no leaks but leave it sit over night and I have an oil spot.
You have to track down where the oil is coming from
MrSoutherland
Car: S13 - Sr20
The half moons in the back where where your valve cover gasket goes.Just a guess
lazysk8er2
Car: 1990 240sx
check by the oil filter theres an oil pressure sensor. almost always leaks.
theres also your rear main seal. oil pan gasket.
