es.biggs »
https://forums.nicoclub.com/es-biggs-u154499.html
Fri Mar 18, 2011 8:51 pm
LOL no you never run a hose from the radiator to the radiator. It does sound like a heater core leak. You have two pipes on the back of your engine, and they run coolant to and from the heater core. You will probably need to pull the plenum to reach the hoses. You could connect those two pipes, effectively bypassing your heater core. You won't have heat, but you will probably have a band-aid fix for your leak until you have the time/money to repair it. I don't know how hard it is to pull the heater core out of this car I've luckily not had to touch one
BTW - bypassing the heater core isn't going to hurt anything except for the fact that your heat won't be hot. The two heater hoses run between the engine and the firewall, right in the middle of the car. All you need to do to bypass the heater core is link those two hoses, maybe with a combination of fittings and an elbow-shaped hose.
The right way to do it of course would be to just fix whatever is leaking in your heater box
