itsa300zx wrote: ↑Wed Jan 09, 2019 8:29 pm
Probably not.
I think we need a lot more background info here, ie did the car run before you started this repair? If not how long did it dit for?Any unusual symptoms? Regular maintenance up to Date? Did you just buy the car? Just to name a few. Before we can suggest some help.
I just bought the car and we drove it 40 minutes back home. It idles well except there were a few moments it sounded like it was about to die on us. Considering it could be multiple factors contributing to it(the car had been sitting for a while and probably has bad gas, there was no air filter, etc) I know absolutely nothing about the regular maintenance it had but the water pump, timing belt, spark plugs and fuel pump were all brand new.
I just checked the hose there was a crack on where the clamp is.
