humroot »
https://forums.nicoclub.com/humroot-u299093.html
Tue Nov 17, 2020 2:52 pm
Hi all,
First post here! Been using the forum and finding pretty much everything i need using the search, but recently ran into an issue that I want to run by you all.
My 2008 S got a P0456 (small evap leak) several months ago that turned into a P0455 (gross evap leak). Figured it was the canister or gas cap or something. Last time I filled up the tank, more gas went in that usual. When the pump finally shut off, I noticed there was gas pouring out from the top of the tank. I am assuming that I have something going on with the pump seal or the evap hose on top of the tank and just wanted to get some thoughts before I drop the tank. Anything else I should do while the tank is off? It has 180k miles and I really dont know too much of the history of the car and I have had it a year.
Thanks,
Jamie
