Leaking fuel tank FIXED *pics*
nickelmedia
Car: 2001 Audi A4 1.8tqms
I bought this 240 about a week ago and smelled a little bit of gas on the way home. When I filled the tank, I noticed a few puddles of gas on the ground. So, today we decided to find the leak and stop it. I bought some JB Weld, expecting there to be a crack somewhere. Luckily there wasn't, but after removing the tank and holding it at different angles, we noticed it was leaking from the fuel pump surround.
The O-Ring is missing from where the pump rests on the tank. We could have replaced the whole thing without taking off the tank but oh well. Here's the solution we came up with.
pull the fuel pump fuse. turn the car over a few cranks to release pressure from the lines.
plugging the lines
Outer ring measures 6 1/8"Inner ring is 5 1/8"
Makeshift gasket material since the nissan dealer had no o-ring.
Compass the circles, cut with scissors.
test fit
draw screw holes
leather tools to cut out the holes
gasket sealer
lining it up
replace fuel pump
After all that I waited about 5 hours and filled the tank. No leaks, No smell! I have no idea how much the O-ring costs, but I know the gasket material was $2 and the sealer was older than me sitting in my dad's garage.
Problem solved and I'm happy
navysnail
great job, and nice work on making your own gasket, im glad to hear it works well
