leaking fuel injector
1989240sx
Car: 1989 240sx and 1974 duster
i have just got done replacing all the injector gasket i felt around the injector and ther is gas around it please help me i am new to injector i am use to carb car like my 74 duster
TougeMS13
Car: '91 coupe
Gregs idea helped on mine. Get some vaseline and lube the rings, dont use the caps with the two screws to tighten them down, just put them in and twist back and forth while pushing down til they seat all the way. Pull out all your injectors if you tightened them down with the caps and check the o rings.
1989240sx
i did twist but did not lube them up so should i get new o rings
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
Get some WD40, or Liquid silicone spray, and spray the o-rings, if you did NOT use lubricant, replace the orings and use wd40 or liquid silicone, spray on the orings, put on the injector, and when you slide the injector into fuel rail and into the engine, spray them again, while they are on the injector...
