vancouverbc »
https://forums.nicoclub.com/vancouverbc-u10923.html
Thu May 11, 2006 9:05 am
****************HC***** CO***** NOX **** HC-Idle*** CO-Idle jan/2006 270,000 36 ppm 0.24 % 17 ppm 355 ppm 2.22 %
oct/2005 268,000 38 ppm 0.23 % 32 ppm 215 ppm 1.57 %
oct/2004 256,000 43 ppm 0.35 % 39 ppm 48 ppm 0.00 %
I failed the idle test for HC and CO. You needed max 108ppm for HC and .84 percent for CO. The initial test was in oct/2005 and I was tested 3 months later in jan/2006. The idle numbers got substantially worse in that 3 months. The first 3 columns are for driving test and i passed no problem.
no rotten egg or trouble passing gas.
Modified by vancouverbc at 12:28 PM 5/11/2006
