leaking coolant
epoch707
I have a faint drip of coolant coming from my block. Probably about a couple drops in 3 weeks. Its not a lot so is there anyway of stoping this leak without changing the head gasket?
edgartheace
Car: 1993 240sx, 1992 300zx RIP, 1993 300zx 2+2, 1993 Infinti J30t
Well it all depends were the leak is at. It could be your pump, freeze plugs, or a hose. Check to see where on the block the water is coming from, and then we can go from there. If its your water pump or a hose just replace them. If it is your freeze plugs you could try radiator sealer, or just all out replace the plug. I would go with the rubber replacement freeze plugs. they are easier to put on than the metal or Brass ones.
boznuttz
Car: MS13
While your car is running, get a nice little peak under it. I was delighted to see my waterpump was just pissin all over me.
epoch707
boznuttz wrote:While your car is running, get a nice little peak under it. I was delighted to see my waterpump was just pissin all over me.
alright i'll try that, thanksIt seems that the leak is coming from the block
