esahuque »
https://forums.nicoclub.com/esahuque-u20709.html
Fri Jun 18, 2010 4:39 am
I had an enthalpy tuned ECU with a SAFC and on the dyno i put down 300hp at 12.5 psi. that's about what i expected out of my t3/t4 50 trim .48 a/r with 8.6:1 pistons. knowing that I could get more power if i had more control over my timing I went ahead and fitted my S14 with a Nistune s13 ecu using my cross over harness from my enthalpy tune. While i was waiting to get tuned i redid some of my IC piping and re-clocked my turbo. Set up a basic tune to start with and hit the dyno with high hopes of getting 315hp or so out of 12.5 psi and maybe 350-360hp out of 17psi. well that wasn't the story, at 12.5 psi i put down 244hp and at 17psi i put down 286hp WTF. we couldn't squeeze out any more power. Even though boost came on quick and held throughout the RPM range only dropping about .5 psi at red-line, i went home and did a boost leak test anyway. come to find out the compressor house was leaking at 4psi right where it meets the back plate. must have happened when i clocked it. I took it apart and put a bead of red RTV around it and let it sit over night. I did another boost leak test and it held up to 25psi. I'm about to pay MORE money to get back on the dyno and tweak the tune some more hoping for more power. does anyone think that was the only problem, turbo become inefficient do to it working harder. or should i look elsewhere. oh and i did a compression test and its freshly built with 170psi across the board.
