leaking bov?
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
How do i know if my stock Bov is leaking?My turbo seems to laggy.
Blown240sx
Car: 1996 240sx
I dont know if you can really hear a boost leak... It might hiss if it is but I dont know why it would be unless it was damaged. Would it cause lag or just low boost levels?
TougeTune180
Car: 1991 Nissan RPS13
i had a slight leak problem at first with my atmospheric one, it was because there was the wrong sized O ring on it, and once i replaced that it stopped, but you could hear a slight hiss if you slowly got on the throttle from under the hood, like twisting open the throttle body by hand. i dunno if the same would apply to stock, but i dont see why you couldnt test it like that. hope that helps, good luck
9240sx
I hear a sucking sound once i start to spool up,But it might just be the turbo sound from the apexi intake.BOV works as it sould,if i let off the throttle it will let out the air,I can hear it loud and clear.
