fallen180sx wrote:i noticed that after i put my bov on (figured out it leaked after about a day) the ca started to get hot.. my temp gauge would hit the H and come back down and go back up.. we drained the coolant system because we thought air was in it.. still did it. took the bov off, and put stock piping back on.. doesnt heat up. whats the bov have to do with engine heat?
You BOV didn't cause your engine to run hot. Hell, your engine may not be as hot as you think. Your temperature sending unit is probable out of calibration and is giving you some wacky readings, so change it. You're not the 1st and you won't be the last.
Dee
