leaking blow off valve?
burninskulls0911
Car: 240sx
i just did a boost leak test on my rb20 and there is a pretty good amount of air coming out of the blow off valve is this a common problem with the stock bov?and the boost gauge is reading about 5 lbs when testing so i would think thats enough vacuum pressure to keep the bov closed?
Bluefire
the stock valve is a bypass valve and doesn't hold shut like an aftermarket blow off valve does...
burninskulls0911
Car: 240sx
Bluefire wrote:the stock valve is a bypass valve and doesn't hold shut like an aftermarket blow off valve does...
ohh thats right so wouldnt it letting air out be a boost leak?for some reason laitly my car has been feeling really slow
PorkChopExpress
Car: rb kouki
the stock bov is a 1st gen eclipse bov. They start leaking I think around 14lbs.
240z4u
Car: '95 Nissan 240SX
If what you say is true (its the same as a stock 1g bov), then the unit does leak at idle by design.
burninskulls0911
Car: 240sx
PorkChopExpress wrote:the stock bov is a 1st gen eclipse bov. They start leaking I think around 14lbs.
ya but when i boost leak test it i only hit 5 lbs but there is quite a bit of air coming out..like when i put my hand in front of it at about a foot away i can fee a good amount of air coming out
do you think i should replace it?
PorkChopExpress
Car: rb kouki
yup, unless you don't have the vac line on it shouldn't leak. I have a new oem replacement 1g bov from dealer. Think I put 10 miles on it. $35 if you want it.
burninskulls0911
Car: 240sx
PorkChopExpress wrote:yup, unless you don't have the vac line on it shouldn't leak. I have a new oem replacement 1g bov from dealer. Think I put 10 miles on it. $35 if you want it.
could i some pictures of it to make sure its the same as mine?
burninskulls0911
Car: 240sx
i just went out to the car and i was messing with it some more and took off the recirculating tube that goes from the bypass valve to the intake and when i rev the engine no air comes out and when i let off it blows off like it should
so now im really stumped because the car is no where near as fast as it should be
about 2 weeks ago it was pulling pretty hard and now it feels restricted first think i could think of would be a boost leak but thats not it so i dont know what it could be
dwnshfter
Car: 91 240 rb20
you
still have it?
PorkChopExpress
Car: rb kouki
no, i finally got around to doing a leak test and my 15 year old bov was leaking.
