So im leaving a small spot of gear oil after i drive the car.And im pretty sure its not the rear main seal,Cause i replaced that not to long ago.Is it a pretty common thing for the oil to leak out from around the different sensors that plug into the transmission?Im alomst 100% sure thats where its leaking out from.
And one more thing,Is there any gaskets or copper washers that i well need to do this job,Or is it just RTV.
-Thanks
