180fan »
https://forums.nicoclub.com/180fan-u3602.html
Fri Dec 26, 2003 10:59 am
is your radiator drained of coolant or is it full still? If it's full, I'd check the reservoir for leaks. If it's not leaking, then check the cap. If that too is not leaking, You can then get a kit to test your coolant system. It'll basically pressurize your coolant system without it being on and you can look for the leaks there. If it's coming from your engine bay, you can usually have a look at your engine pan to give you at least a ballpark idea of where it's coming from. Then start to have a look around that general area for leaks. The usual suspects would be a cracked radiator, old radiator hoses, radiator hoses not on tightly enough, perhaps a leak in your heater hoses, bad radiator cap, and your waterpump. Have a look at those and see what you can find.
