because my dad is a jerkoff and said to just replace the whole rad....it was only $115. it appears to be leaking along the top..so im pretty sure the whole thing needed to be replaced anyway. i also dont have one of those coolant pressure testers. how likely is it to break one of these AC lines?msvara wrote:Wow. Why replace the rad if there's a small leak a d you don't even know where it's from. Take the lower engine cover off and the front intake remove the rad cap and use a coolant pressure tester. Check the level inside and fill to top. Then pressurize the system to about 15 psi. Use a light and look around for the leak. If nothing shows or it's a very slow leak you can get special dye to put into your cooling system then use a uv light to see where it's coming from.
Removing the rad has so many risks associated including accidentally breaking the AC lines.
Hey sorry if I made you upset. If my dad offered advice I would take it provided he has the experience with the specific topic. I'm sure you would as well. I typically google my issues and find the average consensus around an issue then use my own judgement and perhaps even talk to a couple of shops before biting the bullet. It's generally easier to address the issue if you properly diagnose the issue instead of assuming a part failure. It could even be something as simple as the radiator cap seal or the upper hose.cji4130 wrote:because my dad is a jerkoff and said to just replace the whole rad....it was only $115. it appears to be leaking along the top..so im pretty sure the whole thing needed to be replaced anyway. i also dont have one of those coolant pressure testers. how likely is it to break one of these AC lines?msvara wrote:Wow. Why replace the rad if there's a small leak a d you don't even know where it's from. Take the lower engine cover off and the front intake remove the rad cap and use a coolant pressure tester. Check the level inside and fill to top. Then pressurize the system to about 15 psi. Use a light and look around for the leak. If nothing shows or it's a very slow leak you can get special dye to put into your cooling system then use a uv light to see where it's coming from.
