leakin rear strut, active sus
Freakart
Car: 1990 infiniti Q45
2004 Nissan X-Trail
ok, now i know you've prob heard this all before but im lookin for some replacement struts for my '90 q45 active sus, rears, i've tryed searchin the forum and can find what i think i need.....everything i find seems to siut non active sus....can anyone help please?i also need to ship them tyo australia.any help apperciatted
shanec86
Car: 86' HR31 Skyline Passage GT, 89' JDM Q45a
Where abouts is the rear strut leaking? You will have fun trying to find a replacement in australia. Im pretty sure you can still get them through nissan, but prepare to pay over $2000aud per strut. You might be able to find one off a wreck but there are hardly any active q45's in AUS.
Im currently going through the process of getting my active Q to work (in victoria)
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Contact Keith (nico member texasoil). He is the only person here that can really help you. He is super friendly and the most knowledgeable person on the forum regarding this subject.
His websites:
http://www.q45asuspension.com/http://ww ... ys....html
His Telephone numbers:
832-651-7576 713-664-8276
His email address:
[email protected]
lino
shanec86 wrote: Im currently going through the process of getting my active Q to work (in victoria)
How's you active coming along? What have you done and what still needs to be done?
Freakart
2004 Nissan X-Trail
its leakin up near the top some where,will be gettin it up on a hoist on saturday hopfully so ill have a better look then......well i might start callin some wreakers, i think i know of some Q's around dont know if they are active or not tho?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Struts off wrecked cars are very likely just as bad. You'll have to have them reahbilitated also.
Why don't you spend some quality time reading all the posts by texasoil and the FSM?
lino
Freakart wrote:its leakin up near the top some where,will be gettin it up on a hoist on saturday hopfully so ill have a better look
Take some pics if you can and post them here.
sldwys
Car: 1991 rs13 nz new 200sx
hey mate, Im from New Zealand, And Can get my hands on a full set of active shocks from a y33, If your interested give me a yell, my mate is after 250 NZD each shock, plus shipping.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
While the rear suspension is a similar design, it is different in dimension and detail. The MacPherson front suspension of the Y33 is totally different and not in any way compatible.
A wild goose chase these would be.
Modified by maxnix at 9:31 AM 7/2/2009
Freakart
2004 Nissan X-Trail
well it looks as if i might just convert my Q to non active sus......i love my active sus but getting parts or struts fix will cost too much......... i dont wana do this but...........someone give me another option please
sebvox
Car: 1995 Q45 **R.I.P.** 2003 M45
I have access to a retired Q45a at a local junk yard. I don't know if the hydraulics are in decent shape. If anyone wants the rear sway bar I can pull that as well.
lino
How much will it cost to restore and how much will it cost to convert?
Freakart
2004 Nissan X-Trail
im not sure any more....im gettin different opions from everyone i talk to round here? not sure if anyone here can even rebuild the struts, they all say they have to pull them out to see.......
Q45tech
Remember the [20mm] active rear bar is designed to work with the smaller active [28mm] front sway bar. While the difference bewteen 29 and 28 is 13% and that doesn't sound like much, it depends upon WHERE you start and what you desire.
Important for neutral handling that the effective roll stiffness front and rear is matched to the vehicles weight distribution ratio front to rear.
A vehicle that has 54% weight on the front needs 54% of stiffness on the front.......................the difficult parts is how the weight changes on individual tires when you turn, brake, or accelerate.
Obviously a pure fixed mechanical system can on be 100% correct under only one condition.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Have you emailed Keith*texasoil) yet? Either that or get one from Japan.
A proper conversion will cost as much as restoring the active.
shanec86
Firstly, read the FSM active sus section 100 times so i can understand how the thing works.
I have changed the fluid (it hardly had any there in the first place as there was a slow leak from the reservior)
Im going to be plugging in scan tool to pull some codes out of consult and see what the computer thinks is happening and just go from there.
I went and spoke to a Toyota active suspension Guru near me and discussed some options, but like he also mentioned, check what codes are being thrown up first.
(in your case Freakart it probably wouldnt matter if you know its a leak anyway)
This guy rebuilds toyota active struts and has also designed his own replacement active strut. But i know i will be looking at $2000 minimum if we need to start playing with struts
(My father also used to work on the Mercedes with similar systems so ive got plenty of help to get this working)
texasoil
Car: '92 Infiniti Q45A
'94 Infiniti Q45A
'94 Mercedes-Benz SL600
THe Q45 active struts can be disassembled and the shaft seal replaced. Check with your toyota buddy. There is also a 'shock absorber' repair firm down there--I THINK in Sidney that can renew all the seals also--very reasonable
