leakage! help! clutch pedal is leaking
Ca18det240sxchk
Car: nissan 240sx swapped ca18det
ok, so tell me why i filled up my clutch reservoir 3 times yesterday?!!! and its alll over the pedal itself! what could it be?
asher4857
Car: '89 240SX Fastback
i know one thing, your sig is way to big..
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Its because your clutch master cylinder is broken and the seal around the piston shaft is worn out. So the fluid drips down to the pedal. That fluid is the same as brake fluid so I wouldn't let it get on anything that you value such as shoes, carpet, paint, etc...
Bwana
Car: Denali
c-rad wrote:Its because your clutch master cylinder is broken and the seal around the piston shaft is worn out. So the fluid drips down to the pedal. That fluid is the same as brake fluid so I wouldn't let it get on anything that you value such as shoes, carpet, paint, etc...
I'd be 99% sure it's you're clutch master, the only other possibility is a loose line connection that's somehow spraying it back inside. Replace that master.
