180fan »
https://forums.nicoclub.com/180fan-u3602.html
Fri Jun 25, 2004 7:43 am
There could be an adjustment screw at the caliper like on Toyotas. Also make sure you don't have a break in your e-brake cables, that they're bolted into the caliper, that the rear calipers aren't seized, etc.
Might wanna check around your hard lines that run under the car to find your leak also.
